Unable to receive Yahoo mail after updating to iOS 6
I used my iPad for checking my mails on Yahoo. It was working fine before updating to iOS 6 but now I can no longer receive any new messages since the update. I will need to check my mail on my computer which is really a big inconvenience. It is really frustrating because my mails are very important for my job and I need to check it on a daily basis.
What can I do with it?
Best Answer by Wassy24
Answered By 0 points N/A #99876
Yahoo mail is a good communication system. It is really painful when you are missing it after updating iPad to the iOS 6. It may be a problem of internet configuration setting that may be changed after updating operating system. Here are links that are related to your issue-
Answered By 10 points N/A #197198
Hi Hellalife,
Such problems occur when your machine doesn't support new updates.
New updates are for newer hardware and softwares or applications.
Your machine's hardware configuration might be older and doesn't support newer updated applications.
You can remove newer updates and use old settings for receiving mails or you need to update your hardware or applications and it might require you to spend some money as well.
I think this will solve your problem.
Thanks,
Answered By 0 points N/A #99878
It seems that Yahoo Mail works just fine until the Weather App is launched. Thereafter, email no longer works and needs to be retrieved manually on opening the Mail application and pulling down to refresh. The solution is to delete the yahoo email account and reset network settings.Then, log into your Yahoo account on your PC and change your password.Then add your Yahoo email address on the Mail application on your IPad and input your new password. Do not use the Weather App.
