Unable to remove autorun scr file
Hello Friends,
My system is having autorun scr file, It seems to a malware and need to be removed, I am unable to do it using AVG Anti-Virus 8. Please suggest the best Anti-Virus that will Scan and Remove this Malware. If there is any other way  of removing please suggest. Waiting to hear from you.
Thanks & Regards,
Crewe Bob
Answered By 60 points N/A #131811
Hello Crewe,
I would say the task you are going to perform with AVG 8, that AVG cannot perform. What should you do is, first un-install the AVG 8 and install Avast Antivirus software. Which will help you to resolve this issue as well it will protect your system from any future malware. You can download Avast from below link :
https://www.avast.com/en-in/index
Hope this will help you to fix your issue.
