na4d3uida
Posted on - 01/13/2012
I have Mini-Stream Ripper installed on my Windows XP Pro computer. I am running out of space so I want to remove those applications that I don’t usually use. I’ve been trying to delete this one, but I was unable to.
I am using the uninstaller that comes with the software package. The icon was removed from my desktop, but the entire folders that are connected with Mini-Stream Ripper are still appearing on the Program Files folder. I keep getting
Access is denied error when attempting to delete this.
Please help me.
Error Deleting File or Folder
Cannot delete Ripper: Access is denied.
Make sure the disk is not Full or write-protected and that the file is not currently in use.
OK
Lee Seen
Unable to Remove Mini-Stream Ripper Software
You will need to go to the program files and the open the folder that has the contents of that application and delete. Note that you should not delete the folder but the contents that are in it. Even is some refuse to be deleted it is not a problem. Once you have done you will need to go to the control panel, and the programs and features, and then go to add/remove programs. There you will need to locate that application and uninstall it.
If it still refuses, you will need to look for 'Unlocker' and install it on your computer. After that go back to program files and the then delete the folder of that application. In case it refuses, unlocker will be launched automatically and ask you if you want to delete that application, comply.
-Lee Seen
