Unable to retrieve description for the web service Error
I am able to make connection with the server though it is doesn't receive description packets, I always encounter this error message:
Hello. This problem usually happens when the web service is renamed. This causes the location to be mis located. Do not worry. The problem can be fixed. Here are two solution methods which can help you out.
Change your policy file, that might help solve the issue. Follow this:
<?xml version="1.0" encoding="utf-8"?>
<access-policy>
<cross-domain-access>
<policy>
<allow-from http-request-headers="*" http-methods="*">
<domain uri="http://*" />
<domain uri="https://*" />
</allow-from>
<grant-to>
<resource path="/" include-subpaths="true" />
</grant-to>
</policy>
</cross-domain-access>
</access-policy
The problem will be solved. If not, then try clearing your Temporary Internet files and your browser cache. If it is still not working, then you should contact a network and IT expert near your area.
Best of luck with you
You encounter this error because of changing some configuration like the version of the policy or when you use a customized client accesspolicy.xml file. If you have a back up of old policy then use or restore it but if don’t have, you may try to change your clientaccesspolicy.xml to this one.
After changing, you may still encounter this error, try to clear and restart the editor and clear your browser's cache.
This will solve your problem.
