Hi there, the famous ‘Angry Bird Rio’ for pc version could not run on my computer under Windows 7. The trial version of the game was downloaded five times from five different websites. But same ‘ERROR MESSAGE’ appeared every time.
System configuration of my pc is described here.
PC System:
CPU: Genuine Intel (R) T2400 @ 2.83 GHz
Random-access memory : 1.00 GB RAM
OS : Windows 7 Ultimate
Type : 32-bit OS
Graphics :
Name: Mobile Intel (R) 945 Express Chipset Family
Manufactured by Intel Corporation
Total memory: 251 MB (approx.)
DAC type: Internal
Chip type: Intel(R) GMA 950
Monitor: Graphics PnP Monitor
Display mode: (60Hz) (32-bit) 1024X768
And to play ""ANGRY BIRD RIO"" on personal computer with Windows XP/7, system requirements are as follow.
1. OS: Windows XP /7 / Vista
2. RAM memory: 512 MB
3. Processor: 1GH
4. Sound Card: Sound device compatible with DirectX ® 9.0c
5. Video: 3D-video card compatible with DirectX, 128 MB
6. Hard disk free space : 45.2 MB"
Thank you.
Error
OpenGL 2.0 renderer not supported! Reason:
OpenGL 2.0 is not supported
OpenGL 1.4 renderer not supported! Reason:
OpenGL 1.3 is not supported
OK
iamssb
Unable to Run Angry Bird Rio Trial Version
Hello Mishuk!
To resolve this, try the worarounds below:
1. Download Angry Birds Rio Demo Version.
2. Type dxdiag on the Search box on your Start menu.
3. Check on the graphic card installed on your computer.
4. Go to the website of your graphic card manufacturer and then search for the latest updates and then download and install it.
5. Restart your computer.
Remember to update manually and do not use the auto-update. I will also suggest that you purchase the game so you can enjoy playing it completely.
Hope this helps! Enjoy!
John
lee hung
75 points
Hello Mishuk,
From the information you have given, it seems like the game you are downloading adheres well to the system requirements of your computer. And now what could be the problem? Well, one thing we could suspect for it behaving that way is because it a trial version and may be you have used it before and therefore the time that you were allocated to use the trial version is over.
Another possible cause of the problem could be that you are downloading a game setup that is corrupted or has broken links and therefore cannot be installed properly on the computer. When downloading, do not go for illegal websites as it always contains viruses and damaged installer.
__
Regards
Lee Hung
Dear John,
Thanks for your comment. But I've again downloaded the game with full version. After finishing the patch it again started showing the message. See the Attachment please. That the problem I have faced.
Thank you.
Mishuk Rahman
