whiteme
Posted on - 12/12/2011
I have a Windows XP SP3 Tablet PC and had Office Small Business Edition installed on it which I’ve been using for several years. But all of a sudden, any Office applications can’t be use anymore and it requires to be reinstalled. I tried to use Microsoft’s original installer but it won’t work in repair approach, it just gives some lists of programs. Can you please help me on this?
Unable to Run Application in Office Small Business Edition
I had problem same with you to my laptop, then I try to check the system it run good then after that my operating system had problem same with you. This you must do to solve your problem just simply scan if there an infected files or data to your system from worms and then spyware. After you try that just simply try to defrag your hard disk to start defragging just simply click the start menu and go to the computer just simply click the icon, then just right click the drive from the icon and you just simply select the properties then click the icon of the tools, after that you just see the defragmentation you just start defrag your system.
Ben
