Irene Jones
Posted on - 07/07/2011
I was running an application, midway upon it an error interrupted. It shows that;
WinZip_Data_Module is missing – Error (2A-DCCF6)
I was the first time I encountered this error. As an aid, I restarted my computer then start the process again. Same error still shows up. I don't know things like this and what to do with it. Please help me.
Unable to run an application with WinZip
Hi there,
First thing you will do is to try another application to check where the problem is.
If the error still exist with the use of another application perhaps then you're facing a problem regarding a worm infection.
The problem doesn't originate due to application issue but because of a certain worm that is installed in your system.
This looks like there is an error so the worm has not infected your system but instead the error message is just to trick the user to think the work has been damage or inactive.
This is usually transmitted through emails. Better then scan your computer with a good antivirus and download it from a verified source. Don't forget to update the antivirus upon scanning your computer.
