sankara
10 points
Posted on - 09/13/2011
Hi Guys,
I’m using C++ and recently I’ve been unable to run it on my windows 7.
It starts up then this message pops up:
Error:
Microsoft Visual C++ Runtime Library
Runtime Error!
Program: C:Program FilesATI MultimediamainATIDtct.EXE
This application has requested the Runtime to terminate it in an unusual way. Please contact the application’s support team for more information.
I recently upgraded from XPSP.
Could that be the problem?
Unable to run C++ on windows
Some times it happens that a dialog box like this comes and says that Microsoft C++ Runtime Error. Operating system of Microsoft Corporation has some built-in library function. All software uses these library files when they execute.
If they did not found there necessary resource then this error occurs. In other word when some of this library function does not run properly this error happens. You need this software to solve this problem.
According to solve this problem you need to download named “routine error repair tool”. Download this software and install it. It will find that error and also correct it instantly.
You also can uninstall Turbo C++ software and reinstall again if you have that. It will repair your corrupted file.
