ariel chu
20 points
Posted on - 03/10/2012
We have a problem here working with PowerPoint. We can’t save files as we want.
Our designers work with many designs and creative works.
They do very great stuffs, but here is what we came stopped. We are facing an unhelpful error message here.
He has took an screen shot of that error message and clipped it.
Here it is below.
PowerPoint found an error that it can't correct. You should save presentations, quit, and then restart
PowerPoint.
Please someone come and help us with this error –
Unable to save files in powerpoint
When you tried to save your files on Microsoft PowerPoint, were those files created on the same version where you are trying to save them? Or were they edited and being saved on a different version by any chance? There are several reasons why you may get the “PowerPoint found an error it can’t correct” message.
If you are editing files from a different version of PowerPoint and saving it on another, I would suggest though that you try the following first to see if this work-around will help you resolve your issue:
Remove or delete any edited items from the file
Save the original file using a different name
Edit the file again
Save it using the new name used when it was saved previously
