Aldriche
Posted on - 11/02/2011
When I’m adding footage to the video strip, editing and clicking the “Produce” to save the movie in a video file using the Cyber Link Director Express, the error stated below would appear. Upon clicking OK, the software would close even before I’m done saving the movie. I observed that I can save it in a Cyber link Power Producer Express Icon, but when I download the file I noticed that it is almost corrupted. I re-installed the software many times and rebooted in between installation. The worst thing is I cannot remove the remaining files and folders. The message goes like this: “deleting, moving or modifying can cause other programs not properly working.” Please help me how to deal with this problem. I don’t know what to do. Thank you in advance.
Unable to save a movie via Cyber Link Director Express
Hi Aldriche,
I also encountered that problem last week and I solved it by doing the following steps:
Click the huge or big button at the left corner of Cyberlink Director
Choose file and then produce movie
You can choose whatever format that you want in saving it
You can choose .avi . mpeg
Choose the profile type and profile quality that you want
Click next
And then choose wherever you wanna save the movie and hit start rendering
It will be done in few minutes depending on how large the moview you want to save.
Close the program
Take a look at the screenshots below for you to be enlightend on what I have mentioned above:
I’m not sure about CyberLink Director Express but I know there is CyberLink PowerDirector because I’m using it before. If the version you are using is a download, check the system requirements again and make sure your computer meets those requirements. Try CyberLink PowerDirector 13.
It supports Windows Vista (Home Basic, Home Premium, Business, and Ultimate editions), Windows 7 (Home Basic, Home Premium, Professional, and Ultimate editions), and Windows 8.x both 32-bit and 64-bit.
It requires 3 GHz Intel Pentium 4 or equivalent AMD Athlon 64 X2 or faster processor, 2 GB RAM, video card with 128 MB video RAM, 6.5 GB free space, Windows Media Player 9 or higher for playback features, 1024 x 768 minimum screen resolution, and internet connection for product activation and other online services.
