Hello all,
Recently, I have submitted my item on EBay for selling, but unfortunately, none of the buyers can purchase my item. There are some sort of a technical issues I suppose. I get the following error on my screen:
Your request could not be processed at this time
Sorry, due to a technical issue with this listing, this variation of this item cannot be purchased.
I have contacted the EBay support, but unluckily, they could not help. If anyone of you can help me resolve it, I'll be really obliged.
Looking forward to your reply.
Kind regards.
dnblack
Unable to sell items on EBay
You are not the only one experiencing the problem. I have a few ways you can use and your problem will be solved. First Delete Cookies and Temp Files then check for updates for your browser. After that check the updates for your operating system and restart your machine.
If it still persists the same problem update java and flash if you are using explorer or Mozilla go to http://www.adobe.com/products/flashplayer.html and follow the instructions for downloading and installing. Afterwards, Reset Your Network Connection Following the instructions in this thread: http://forums.ebay.co.uk/thread.jspa?threadID=1200198119&tstart=0. Am quite sure when you get to this your problem will be solved
