I am trying to send an email with my iPhone 4G but I am receiving error stating that I need a password for my email account. I’m pretty sure that I typed the password correctly together with the username. How can I fix it?Â
Unable to send email using iPhone 4G
My partner and my spouse and i actually presume you're utilizing IMAP?
Try to look up the actual websites (and also rss feeds) for details how to allow Port 465 (or even preferable Interface 587) as the entry interface for you personally electronic mail, which will necessitate you to definitely attest prior to sending email.
I would critically advise a person update the Zimbra server to type A present discharge as soon as achievable.
May this help you a lot. And thanks for giving a chance to help you out as I have the same problem facing with my iphone but I done the same procedure. It's okay now.
