I am getting an error message in Outlook express that I am using. I’m only able to send messages, but unable to receive any messages. I have cleared all my junk emails. Some of the experts have said that my inbox file is corrupted or damaged. Error message is : 0x800C0133. I am unable to correct this error with this file Inbox.dbx.
Please help me.
Unable to Send Messages – MS Outlook Error: 0x800C0133
Dear Sabrina Becnel, I have read your query about Microsoft Outlook Express Error 0x800C0133. It seems that inbox.dbx file has become corrupted; missing or its attributes have been changed to read only by accident. To fix this problem please follow these:
· Restart your computer and see if it resolves your issue. Sometimes this problem will be fixed by a system restart.
· First of all set your folder options to view hidden files. To show hidden files, just open any folder on your PC, click on Tools and under Tools you will see Folder Options. Open Folder Options and under View Tab you will see Files and Folders option. There, select Show hidden files and folders and click ok. Now open Outlook Express and go to Maintenance under Options from Tools. To view stored files location has a look at Store Folder. Memorize the path and navigate to that location. Make backup of you Emails and close Outlook Express, then delete Inbox.dbx, after restarting Outlook Express Inbox.dbx will be created again automatically. This may resolve your issue.
· If your Anti-virus is scanning your Emails, then don’t let it to continue scanning. It may also resolve your issue.
I hope it helped.
Follow these simple steps to repair your corrupted indox.dbx file.
* Open outlook express.
* Open local folder in navigation, rename it after Temp.
* Go to tools -> options -> maintenance and chose store folder and remember inbox.
* Close outlook express.
* Now delete file inbox.dbx.
* Now Open the outlook express again and import your email from Temp to inbox. You inbox is new repaired one.
