Unable to Synchronize Google Calendar to MS Outlook: Error Code -2146959355
Good day, everyone at Techyv!
I cannot synchronize Google Calendar with MS Outlook. What is causing this problem with the two?
How do I fix it – do I need to reinstall or change anything?
Thanks a lot for helping me solve this problem.
Error:
Could not connect to Microsoft Outlookâ„¢: error -2146959355, code 0
Answered By 590495 points N/A #95273
Check your internet connection using your default web browser and see if you can connect freely to any website.
If there is no problem with your internet connection, check your computer for errors that is preventing Microsoft Outlook from synchronizing with Google Calendar.
Use your disk utility application if you have any or just use Windows’ basic disk check.
  1. Right click on drive C and then select Properties.
  2. Click Tools tab.
  3. Click Check Now.
  4. Check Automatically fix file system errors and then hit Start.
If you did not find any problems in the hard drive’s file structure, update your antivirus and then run a full system scan on your computer to check if a virus is preventing this error.
If the system is clean, uninstall Microsoft Outlook and then install it back again.
Much better if you replace it with a new version.
