Unable To Find The Screen Pinning Option
Screen pinning option is not available in the latest Android version. After the update, I am not able to pin the screen by the conventional method. Is this option removed in the new update? Can any third-party apps be used for the screen pinning? Is the feature removed? Will it be reverted in the future updates?
Answered By 50 points N/A #317892
Screen Pinning is still available as the option even in the latest Android update. There could be an issue from the user’s end if you are not able to see the screen pinning option. There are two ways to methods to resolve this issue. First of all, you need to know your navigation system. If you are using gesture control, swipe up for the drawer, otherwise, click on the home button. Once done, long press on the app icon and wait for a pop-up. Here, you will see an option to pin the screen.
If this method fails, that means, you have not activated the screen pinning option. For this, you need to go to the security option and click on advanced. Here, you will see an option to turn on the screen pinning.
