Unable to transfer pictures from my Iphone4 to my Nexus S
I love the auto focus feature of my iPhone better than that of my nexus S.
I wish I can transfer the pictures I captured from my IOS device to my Android device without the use of computer.
I tried using Bluetooth but I can’t get it to work properly.
Does the operating system have an effect on this?
How can I get it to work?
Or at least transfer files.
Answered By 0 points N/A #128622
Unfortunately, apple limits the capability of the device to communicate with another operating system. The way apple developed their software, it will most likely, not work with any other products. Unlike with android which is generally free for all. Can you transfer pictures from the android to the iPhone without any problems?.
If not, then you can download a program in android which you can synchronize data from android to iOS.
One techy guy was able to develop a program so it will act like iTunes running in android phones. You might want to check Google about that. Another possible solution is to buy simple camera zoom that you can buy on amazon or ebay.
It is commonly used with iPhones but they also sell items for other phones.
Hope this helps.
