Unable to unarchive “corrupt.zip” into “Downloads”.
Hi guys,
Here’s a screenshot of the error that I encounter when I tried to view the contents of my zip file:
Archive Utility
Hi guys,
Archive Utility
1. Zip recovery. This is a system that has tried to put all files in the archive so compact that failure at some area of the archive is seen at hand. As such the zip file is seen to be caused at the system settings. The motion of the system with the functionality seems to be perfect. However you may get something of it by installing WINRAR and then unzipping the contents from the archive.
As such the documents be posted to the form of the WinZip for recovery of corrupted files. That is already achieved. As such the work at hand is done and kept in patience at the disposal
thanks.
