Unable to undock/unpin a tab and or merge tabs in IE 10
50 points
Posted on - 07/03/2014
I used to be able to undock/unpin a tab and open it on a separate window when I was viewing multiple tabs in Internet Explorer 10. If I had separate windows, I used to be able to merge them as well. I tried resetting IE and it didn't worm. Any ideas how I can get the tabs to work the same way it did before?
