Unable to update from Update Manager – UBUNTU
20 points
Posted on - 02/10/2012
Hi all!
My desktop alter to UBUNTU classic without unity after installed ATI RADEON HD 6470M driver from ATI website. I resolved it by uninstalling it.
Now the problem I am facing is I am unable to update from update manager and failed to activate additional driver. Want to change my system to default. I am running 32bit UBUNTU 11.04.
Any help will be appreciated highly. Thank you.
The package system Is broken
Check if you are using third party repositories. If so disable them, since they are a common source of problems. Furthermore run the following command in a Terminal: apt- get Install -f
Details
