I don't know where to post Super user or Webapps.
Here's the situation: I am using Google Chrome Canary. I can't upload any image to Facebook. I have tried on Facebook, which works perfectly ok. How can I fix this on Chrome?
Edit: I have tried on chrome stable version 17. Same thing happens. I can't upload any image to facebook.
Expecting your help.
Unable to upload any image to Facebook using Google Chrome Canary
We all know there are two link to upload photos on Facebook.com. To use 'Add photo/video' link on top is better than another on left. Because it doesn't use flash. But if we try using photo link from the left panel, it fails to upload because it uses flash. Now what kind of link you need. Use according to your need.
I think your problem will be solved.
Hathy
Maria Jacksonn
First, you have to check the settings of image showing which should be enable.
Second, your flash player might not working properly. You have to download flash player new version from this link
then you have to install this.
Best regards
Brandy Gilmore
