Unable to upload file through secure client version 5.1
I am using below a specified command, through a batch file. The command and its options have no issues, as per the usage guide of secure client but on running the batch file, I am getting an error, "site not found" (see below image). The issue is somewhere at my server end, since others are able to perform the file upload activity in the same manner.
"G:Program FilesAxwaySecureClientstclient.cmd" httpsu:/username:password@hostname:443/ G:RecfilesLACTestUpTEST_*.zip /prefNoAskSched /quitWhenDone /progress /Remote-Site RCTSENDTST
Appreciate if someone can suggest any network setting change, or any other setting on my server.
Thanks in advance!!!
