Hello!
Please help me solve my problem regarding FrostWire. I am using Windows XP Professional SP3. I have updated my JAVA to the latest version. I wanted to use a second account of FrostWire with it but I was unable to. When downloading in FrostWire, the downloading progress will instantly start but will suddenly stops.
An error message came out and was just giving me three options which are either to retry, to abort or to cancel the download. I tried the three but nothing worked. But it actually works fine with the first user account. Please help me fix this error.
Unable to use FrostWire after updating JAVA
Reinstall Frost wire. Your current Frost wire installation may be corrupted. Before reinstalling Frost wire uninstall your current Frost wire installation using the Windows Control Panel. After reinstalling,download the latest version of Frost wire and execute the download file to reinstall Frostwire.
Frostwire requires java to work properly. If the installation of java is corrupted, repair the program to restore functionality in Frostwire. Before reinstalling Java, uninstall the current version of java.
After that, reinstalling the current version of java. Execute the download file to reinstall java. Unblock the FrostWire form your Windows Firewall, click "START" type "Windows FireWall" and click the "Windows FireWall" search result. Then follow the way.
