Unable to use Powerpoint viewer on Windows 7
The error "MSVCR80.dll is missing" appears everytime I use PowerPoint viewer on Windows 7.
It would suggest reinstalling the application to fix the problem. I'd like to know if there are other alternatives I can try before reinstalling the program.
Thank you!
Unable to Locate Component
This application has failed to start because MSVCR80.dll was not found. Re-installing the application may fix this problem.
Thank you!
