Unable to view Picasa on my MAC machine
I have a Mac IBook 10.5 and I have been using it from a few months. I am trying to open my Picasa photos viewer on my MC machine and I am not able to open it.
When I try to click on the Picasa , the usual way I do on my Windows machine I get an error message.
You cannot open the application “Picasa.app” because it is not supported on this system.
I am not sure if this is a compatibility issue with MAC or do I have to install some application in order for me to view my photos.
I thought someone would have come across the same problem, so posting it here for help.
Answered By 0 points N/A #96740
Yes, you need to install Piccasa application. It is possible to download it, for example from Google (http://picasa.google.com/). It should work well on Snow Leopard.
It might happen that it will crash, so try to uninstall and install it again.
If there is still a problem, maybe you should try to install iPhoto which is quite better.  iPhoto is integrated throughout the entire Operating system and it has a better system of working, with external editors. Plus when you install Picasa, you give Google the right to update the Google software, on your machine which may cause a disaster, if the update is flawed in any way.
