Unable to work with Photoshop Elements under compatibility mode
Hello friends,
I am running Vista Home Premium on a very fast computer, but even when I run Photoshop Elements under compatibility mode, it does not work. What happens is that the canvas is missing transparency on the right and top sides.
There are also a lot of random glitches.
What should I do.
Please help.
Answered By 10 points N/A #142450
There is a problem in your Photoshop Elements software. As what I have observed a lot of computer users are having problems when they are using software in compatibility mode such as Adobe Photoshop, Indesign, Dreamweaver, Flash and many more.
Most of the time, Photoshop Elements encounter errors most of the time especially when the software was in compatibility mode.
When it is in compatibility mode there are limited resources in the software that you could use so it is better to download Photoshop Elements that is compatible to your Vista Home Premium Operating System. You could download it to Adobe website for free trial.
