Proova
Posted on - 09/23/2011
I was using a named “Unblocker” Version 1.8.8. After some days I got this message when I tried to open the software! “Error Debug Privileges”. The software is not running and I am in big problem. How should I solve the problem?
Unblocking software error message showing.
There are many reasons for it. May be your computer is corrupted with virus. So need to use updated antivirus and scan full computer. Other way to solve this, just uninstall those corrupted program and then run a cleaner as example cc cleaner, Reginout cleaner etc and restart your computer. Then install those corrupted program again. It will never create that kind of problems.
Or may be most of your software files are corrupted or damaged for not having proper shutdown process or something like that. In this case install and overwrite that program with new update. Installing new update will restore all damaged files.
