Incompatible version of Airport Utility of Apple
Will Apple face its sales graph decreasing due to incompatibility version of Airport Utility with IPv6?
Hello there!
Apparently, a lot of users of Apple products are complaining because of incompatibility of the Airport Utility. Then again, there are circumstances that Apple might face decrease in sales graph because of this but Apple Inc. is trying their very best to improve their products.
There are old versions of the product that are known to be incompatible and in this situation, I suggest to better delete the old version and install the newly updated one by Apple. With this, I hope people be informed. If the problem still occurs, try to go to an Apple store and ask for their help.
Hope it answered your question.
Francis
To avoid having any problems with Apple’s AirPort utility, you should set it up properly for smooth operation.
Here are the steps on how to setup AirPort Extreme over your preferred devices. The steps that will be discussed will use the WiFi network instead of using the one you asked, the IPv6. The steps below can be done on an iPad, iPhone, iPod touch, and or Mac PC.
You are now connected to your new network. Additionally, the IPv6 that you mentioned is a networking protocol that needs to be installed separately or manually but it does not appear in the list of components in the LAN’s connection properties in Network Connections. If you will check your connection’s networking properties, you will only see Internet Protocol (TCP/IP). The IPv6 does not appear on the list. If you want this to appear, you need to install it manually via the command prompt if you are using Microsoft Windows.
Notifications
