What are your technical observations on the charging unit and the charging system of Nintendo Wii U? As compared to other handheld and portable game consoles or gamepads what can the Nintendo Game producers pick up from others sources that can improve the current state and value of the Nintendo Wii U? My name is Kelvin from Ghana. Thank you.
Understanding the charging unit and charging system of the Nintendo Wii U
If you have a Nintendo Wii U gamepad, here’s how to charge it. To charge the gamepad, put the cradle on a flat, stable surface then make sure the AC adapter connector plug is facing in the right direction before you insert it into the charging cradle. Insert the AC adapter connector plug straight all the way into the Wii U gamepad cradle.
Put the Wii U gamepad gently into the gamepad cradle then plug the AC adapter into the power outlet. When the battery begins charging, the battery LED will light orange. Now, once charging is complete, first, unplug the AC adapter from the power outlet then second, disconnect the AC adapter connector plug from the gamepad.
1....
