Understanding How To Convert BMP File To Jpg Format
I wish to convert the BMP file to jpg format, but I am having trouble. Please teach me how to convert BMP file to jpg format and reply soon as I need it urgently!
Hey! There are several ways to convert BMP file to jpg format. You can use Adobe Photoshop for the conversion. Once you open the file in Adobe Photoshop, select Save As and change the file type to JPEG. Then save and click on OK. While using Microsoft Photo Editor, open the file in the Microsoft editor, and while saving, change the file format to jpg.
Now, save as usual. You can also convert the file to jpg online. Websites such as zamzar.com provide tools for such conversion. Simply add the file and select Convert Now. Download the jpg format file you get after the conversion. I hope this helps in understanding how to convert BMP file to jpg format.
Notifications
