Understanding what registry cleaning software does
By downloading the pc registry on your hard drive this allows your pc registry to be cleaned, scanned for malware,it will speed up the performance of your pc, in terms of the process of accessing files, browsing the web , there are different registry cleaners that can simply be downloaded from the web,or even be installed using a cd. It picks up all threats detected from sites you may open, as well as be able to warn you as to how harmful it may be to your PC.
It is a very useful tool one should have.
Hope this helps.Â
Hi there ,Â
It seems you need  details regarding the registry cleaning and what it does actually.
You know the registry is a collection of meta data and other stuffs of the windows and other Software's. Each program may or may not use the system registry .
I case of accidental deletion or mal function of certain Software's or drivers the software may or may not be vanished but the registry entities stay there.The only way to clean these broken entities is through third party Software's. Doing it manually is rather a heculean job.
Examples of such third party Software's are :- registry cleaner , Ccleaner , tune up utilities etc.
I personally recommends Ccleaner .
