As I want to protect my desktop from viruses and others, I have grown to understand that autodesk block host file are for blocking malicious files and other software, sometimes it even blocks those that I still need. With this, can I unblock some files or software that I don’t want to be blocked and how would I be able to do it?
Undoing autodesk block host file
Hello ,
As you running Autodesk on your desktop to protect it from viruses or other malicious files you can not unblock it for all the files. Because you can't unblock it for a single or some of files. If you unblock it will unblock for all files with viruses and malicious files too. So you have to unblock it easily by uninstalling it or removing it from your machine.
Thank you.
