An unexpected error occurred, camtasia is terminating regularly
Hi there,
I had this error when I have opened Camtasia. I didn’t even started to work with the program and this error appeared. Now the program is not working at all. Is there a way to fix this error without reinstalling the program ?
Thank you !
Unexpected Error
An unexpected error occurred. Camtasia is terminating.
Close
Answered By 0 points N/A #176376
This error is definitely common occurs by everyone but there is a solid solution for this problem. Probably, there may be some conflicting problems between your system using software.
I suggest you that first, you check the compatibility of this software with system' specs because most of the problems occur du to this common mistake. If you are unable to resolve the problem and have confirmed the compatibility then you can solve this problem by downloading the software from trusted website.
