Unexpected Error Occurred on Remote Web Access
I just set up Remote Web Access (RWA) on Server Essentials R2. It was working perfectly fine for the past weeks, however, I cannot connect remotely this morning. I can logged on to the site but an error always comes up on clicking on the shared folder. Please tell me how to fix this issue. Thanks.
Message from webpage
An unexpected error occurred. Please try again. If the problem continues, contact the person who manages your server.
Answered By 1065 points N/A #105300
This could be due to the following issues:
1. You are receiving unexpected errors on accessing the shared folders remotely.
2. Missing IIS handlers.
3. You go to IIS > server level and then include the managed handler mapping such as:
Request path: *.svc
Exe.: System.ServiceModel.Activation.ServiceHttpHandlerFactory,System.ServiceModel.Activation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
4. The script mapping that has added are:
Request path: *.svc
Exe.: windir%Microsoft.NETFramework64v4.0.30319aspnet_isapi.dll
Request path: *.svc
Exe.: windir%Microsoft.NETFramework32v4.0.30319aspnet_isapi.dll
5. Launch IISreset.
6. You can be able to access the sources in the Remote access now.
Alternatively, you can also fix this by launching the Command Prompt as the Administrator and then enter the command, IISreset and press the enter key. This will surely fix the issue.
