Hello brainy,
When I try to update the internet security in my computer I got this error message. I think this update has made some corruption in the computer. The error describes me that some dll file is damaged or corrupt. For your information, I have QuickBooks in my computer. Tried the solutions described in the error message, but no result. How to fix the damaged file? Please help. Thanks in advance.
Problem: There was an unexpected error reported while trying to run QuickBooks with company file””.
Solution: This should only occur in rare situations. Such errors can sometimes be solved by restarting your computer, restarting all computers accessing the file in multi-user mode or perhaps reinstalling QuickBooks if the problem persists. If you need assistance, and decide to call Customer Support, Please give the support representative the following information.
Error Code: 80029c4a
Description: Error loading type library/DLL.
points
An unexpected error reported while trying to run QuickBooks
This error is caused because QuickBooks may be downloaded a background update that is not installed completely. Or an incorrect version of the .Dll file QuickBooks used.
Intuit recommends 2 methods for this issue. For the best result, do the techniques in the order shown:
Solution 1:
1. Update QuickBooks to the latest release. For the latest one go this site.
2. Run reboot.bat.
Open the folder containing the reboot.bat file:
a) Wondows 7/ Vista: Right-click the “QuickBooks” icon >> select “Open file location”.
b) Windows XP: Right-click the “QuickBooks” icon>>select “Properties” >> click “Find Target”.
Double-click the “reboot.bat” file.
If the problem still persist, try Solution 2:
Perform a clean install of QuickBools. It is necessary manually to remove QuickBooks installation files & folders left behind by the Microsoft Add / Remove Programs utility. Performing this technique is frequently referred as a clean install or a clean uninstall which help isolate/ resolve issues with QuickBookks.
Now your problem should disappear.
