magdelina
Posted on - 10/08/2011
When the game was running in Windows Vista, an error message sudden came and quite the game. The message wrote 'an unexpected high volume…server to crash. Press alt+f4 to restart the game'. What is the meaning of this message and why it came? Is it due to high volume of graphics loaded into memory which is beyond the capacity of processor and graphics card or something else. If anyone know please let me share.
An unexpected high volume of complaining has caused server to crash. Press Alt+ F4 to restart the game.
Magdelina
This would depend on what game you're playing. Based on my knowledge, this is not a Windows error, so I would assume that this is a game error. You may also be right. If you're computer can't meet the game's minimum required specifications, then there's a high possibility that this is what caused the error. Another thing is that, if you're playing an online game, it may also be a connection error. It could be that your internet connection is not enough for the game your playing. If it's still not the problem, it could be a problem with the game itself. What you could try to do to resolve this is by uninstalling and reinstalling the game. If problem still persist, try to install it on another computer. If you don't have another computer, make another admin user account on your computer and install it there. If it still doesn't work, you mentioned that, "when the game was running in Windows Vista, an error message suddenly came and quit the game." What you could also try is that, installing the game using another OS, such as, Windows XP, Windows 7 or any other OS that you used before, that worked with the game.
Hope this helps.
