Greetings!
I Just installed FL Studio 10.8 beta and tried to open a project, which is created in 10.61 beta, Got the message that "something went wrong.." and "unexpected memory leak" with further details:
"An unexpected memory leak has occurred. The unexpected small block leaks are:
This project consists of long .Wav tracks and there are no other plugins other than limiter and parametric eq2 on active FX channels.
FL Studio 10.8 Public Beta Setup
Unexpected Memory Leak
29 – 44 bytes: EAccessViolation x 1
125 – 140 bytes: UnicodeString x1
Hello Suttie Nickolas,
Unfortunately, I don't have any good news for you. You are trying to install and run the expired version of the software.
The error you're getting is still hanging on the installation, even if you managed to get to the part of the opening the file. The version you are trying to install is 10.8 beta. It was released in October 2012 and has expired in December 2012 and it's normal you can't make it work.
The only thing you can do is to use the older and full version that is working or to check for the newer version on the
http://www.image-line.com/.
Best regards,
Drake Vivian
You received that error because you are installing a beta. Beta versions in applications are normally used for testing and bug discovery. If you want to join other beta testers in testing the program, check the system requirements of the program before installing it. Make sure your computer meets the requirements.
But if you want to use the program for production, you should download the final release and not the beta version. To download the latest version, go to FL Studio download page to get the full installer. This downloads the trial version of FL Studio. If you have an account, you can enter your account to unlock the trial version.
The latest version of FL Studio at the moment supports Windows 7, Windows 8.x, and Windows 10. It requires 4 GB RAM and 4 GB free space. For Mac, it supports OS X 10.11 El Capitan, 10.12 Sierra, 10.13 High Sierra, and 10.14 Mojave.
