Unexpected program error while trying to install ArcGIS 9.0
An error has encountered when I was trying to install ArcGIS 9.0. I completely removed Alta4 ImageMepper before installing ArcGIS 9.0Â then why did I encounter this error message? I have tried to reinstall this application but the same error message disturbed me. Is there any way to fix it? Help me with proper guidance.
An error has occurred in the application. Record the call stack sequence and the description of the error. Error call stack sequence cmdApply_Click writeOutInterfaces ImplementInterfaceInCurrentClass WriteOutInterfaceMethod GetArgumentString Description Object variable or with block variable not set
