Unfortunately Android Settings Has Stopped Working
I am facing an issue with my smartphone. Whenever I try to open the Settings, it is showing “Unfortunately Android Settings has stopped working.” I am, therefore unable to change my Settings. How do I solve this issue?
Answered By 0 points N/A #317985
This may be due to corrupt cache files. So you have to clear the cache files. To do so press on the settings icon till you see a pop-up. Now click on app info and then click clear data. If this did not work, then delete your Google account and Google Play services and again create a new one. Otherwise, a simple factory reset your phone. Even if the factory reset does not work, you have to root your phone, delete settings app and install it again. I hope this will solve your problem.
