Unhandled Access Violation Reading 0xffffffff Exception at 1a06063h.
While I was working in AutoCAD suddenly I had this error without a reason. Is the first error that AutoCAD gives and after I clicked OK the program closed. I started the program again and it worked. The problem is that I have this error more often. Any solution for this error ? What is causing this ?
Thanks !
