“Unhandled e06d7363h exception” error on AutoCAD
Hi Experts.
I need to know the details of the following error message.
AutoCAD error aborting
ERROR FATAL: Unhandled e06d7363h exception……
Please help.
Hi Experts.
Please help.
Hi
Either one of the solution will work for sure.
Hi.
To fix that error you don't need to fix your registry. The course of that error is in broken .Net Framework. To fix .Net go to control panel and select Remove programs. From there remove all .Net packages. Open your browser and download .Net 4.0 package. It is found here Microsoft .Net 4.0 package. When it finishes downloading install it, reboot your PC and start AutoCAD. Also download all AutoCAD updates.
Queen Norman
Notifications
