Unhandled Exception Error in AutoCAD MEP 2010
I’ve been using AutoCAD MEP 2010 for about a month now and aside of having common errors such as “running out of memory” and some occasional unique errors; everything seemed to be fine until now. When I tried to use it once again, I suddenly received an error stating that “Unhandled exception has occurred in a component in your application.” Two of my PC’s are having the same error. I have already tried everything I can to resolve this problem such as Repair and Re-installing but I still get the same error message. Can someone please help me?
AutoCAD
Unhandled exception has occurred in a component in your application. If you click Continue, the application will ignore this error and attempt to continue.
Index – does not have a value.
