Unhandled exception error using the Pitch Helix command
Hi all,
I am a new user of a software developer kit Pitch Helix. I am facing a problem. I want to select a circle but either picking it up from the center point or its diameter but i cat do it. When I select it from the axis button in the dialogue box, an error appears
Variable pitch thread
Unhandled exception has occurred in a component in your
application. If you click Continue, the application will ignore this error
and attempt to continue.
Object reference not set to an instance of an object.
Details                                                          Continue
I don't know why it happens so but I doubt it that this happens because of the profile selection which is not up to the mark.
Please study the image above. It might be of some help to you to answer the query.
If anybody has faced such a problem and then found a solution, please do let me know.
I am stuck at this point.
Waiting for your replies,
Hiliary
