Unhandled Exception with HSTouch Interface Design Software
I’m having an error when starting my Home Seer HSTouch Interface Design Software.
It is so frustrating since I purchased this software for $199.95.
If I am correct, does the error is stating some issues with JAVA?
I encountered an almost similar error before but not with HSTouch software and manage to resolve by a friend.
If anyone here who has an idea on how to fix this, Can you help me please?
Thank you.
HSTouch Designer – Sample-Project
Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately.
Object reference not set to an instance of an object.
See the end of this message for details on invoking just-in-time [JIT) debugging instead of this dialog box.
*********Exception Text********
System.NullRelerenceException: Object reference not set to an instance of an objec
at HS TouchDesigner.StartUp.SetConnectionStatusReal()
at HS TouchDesigner.StartUp.SetConnectionStatus()
at HS TouchDesigner.StartUp.xf6cdc1b28f5b8a05(Object xe0292b9ed559da7d, E
at System.EventHandler.lnvoke(Object sender. EventArgs e)
at System.Windows. Forms.Form.OnLoad(E ventArgs e0
Details                      Continue    Quit
