Unhandled exception occurred on Gizmo Control Center on accessing database
	Hi there,
	I deployed a Microsoft .NET Framework application that accesses a database on a computer. The computer only has the .NET Framework Redistributable package installed.
When I run the application I receive the following error message:
Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If You click Quit, the application will close immediately. The type initializer for ‘Gizmo.Gizmo’ threw an exception.
Here is a picture to better describe my problem:
Have any idea?
