Unicode KB Issue while updating Windows 7
I want to know if anyone has faced problems while updating windows 7 for Unicode kb? Please share your experience with me?
Hi, Mackenzie.
Please check your language settings from Control Panel→Region and Language→Administration→Change Language for Unicode. Also make sure your computer’stime is correctly set.If you are updating your Windows 7 to get the latest Unicode, there is an alternative and easy way.   Normally, with all Microsoft applications, Unicode is updated to the latest version when you update your internet explorer. It is the easiest way to update the Unicode version on your Windows 7 operating system.Â
Skarbos Jay.
