Uninstall 4Sync uninstallation Error occurred
Dear,
4Sync is third party software, I want to remove this software from my computer system, but when I tried to get started this process, and I faced an error message. Now, I am sharing this error message with all of you to find some solution, please.
4Sync-Uninstall
4Sync is still running. Close it and click ‘Retry’ to continue or click ‘Cancel’ to abort uninstallation.
Please help me in connection with the above concern.
Best Answer by Jiraalbert Namat
Answered By 10 points N/A #170852
Hey Alison,
It seems that the software is still running in the background or some of its features are still being used in some application. So in this case I recommend you to use a special UNINSTALLER PROGRAM or Software available online. I can suggest you some of them like Your – Uninstaller (download link) and the other one which is also a freeware CCleaner (Download link). I hope this will be helpful.
Answered By 0 points N/A #170853
If you want to uninstall 4sync, you have to close all running 4sync processes or close the browser. Then, you have to activate the un-installation program in the Add/Remove program in Control Panel. To do it, go to the Start Menu > Control Panel > Add/Remove Program and then locate 4sync in the currently installed programs. Click the remove button and then click next in the pop-up window. Choose Uninstall to Remove the 4Sync.
Once removed, click Finish and reboot the system.
There are still some temporary files left in your system that you need to delete manually.
Go to the Start Menu > Run > Type "regedit" > Enter.
Click the file menu in the registry editor, choose export and click "All" and then browse a location to Save the data and click Save.
Browse a folder named HKEY_CURRENT_USERSoftware, Right click on the 4Shared toolbar folder and choose "Delete" option.
Thank you.
