Uninstall Babylon Toolbar and search engine
I accidentally clicked on a ad banner of Babylon, now I'm sucked with it's toolbar and search engine.
I can't find a way to uninstall this. So a little help here.
Hey Badbd09!
Sometimes babylon toolbars installs with some other sponsored softwares and sometimes it installs from any ad or banner clicked by us. (As you did).
If you are facing this problem, do not worry I have a simple solution for you.
First, if you want to disable this toolbar, just press right clicks on it and "Uncheck" the babylon toolbar. You will not see babylon toolbar anymore.
Secondly, to completely remove it, Go to control panel > Add/remove programs. Search for the babylon toolbar.
Once found, uninstall it.
Your browser will not show babylon toolbar anymore.
Just say goodbye to your problem
Thanks
Which browser are you using? If you are using Mozilla Firefox, click on Tools and then Add-ons. Go to the Extensions tab and then locate the Babylon toolbar installed and then click Remove or Disable.
If you are using Google Chrome, click the wrench icon and then select Tools>Extensions. Or type this on Chrome address bar directly, chrome://settings/extensions. See if the toolbar is listed there. It is usually called as Babylon Chrome OCR. Click Uninstall or Remove.
