How can I uninstall the DivX Plus Media player installed in Program Data DivX folder. I am unable to locate the software in the Program List and also in Revo Uninstaller while trying to uninstall it. Please help me uninstall the program.
Uninstall DivX Plus Media player installed in Program Data DivX
Hello.
You have uninstalled the program from disk drive or memory where this files or folder existence. if you unable to find this program you can go system file only for uninstall.
1. Go to the disk drive memory where it locates like explorer.
2. Find the Div X player and select program the click uninstall.
3. if it is not helpful you can remove it from "C" drive folder. go Users and programs. Search the folder and manipulated file then uninstall. these will logically safe and doing better perform. After had done it. Your system need to restart because all galleries will effect on this applications.
Thank You
