To Uninstall The HP Deskjet 450 Printer Driver Using Simple Steps
Hi. I want to uninstall the HP Deskjet 450 printer driver. I do not know the steps to do so. Can you please suggest me the steps for the same? Thanks in advance. Please reply ASAP.
Hi. The steps for uninstalling the HP Deskjet 450 printer driver using add or remove programs utility require you to first turn the printer off. Next, remove the USB cable and open the control panel from start and then settings. Select add or remove programs option by clicking on it twice. Then, as per the OS, select the HP Deskjet 450 printer uninstaller and click on add/remove or change/remove option. Then, some instructions will appear on the screen which needs to be followed. The diver can be removed without the Uninstaller as well by turning the printer off. Next, remove the USB cable and click on start, settings and finally printers.
Then, delete the HP Deskjet 450 printer after right-clicking on it. Confirm the deletion by clicking on yes. Then, click on OK and close the window of the printer.
