Hello Friends,
I need to uninstall iMacsoft iPad Video Converter from my computer, that too completely in an all efficient manner. Please advice, How to do it, because earlier i uninstalled another such application, just by dragging it in the trash, but the left over preferences, widgets, settings, were arising problems by slowing down the Mac performance.
Please guide me to avoid such issues in uninstalling iMacsoft iPad Video Converter,
Kyle M Arteaga
Uninstall iMacsoft iPad Video Converter
Hi Kyle,
Perhaps you should try using an uninstall app like AppCleaner. This will help you to uninstall your app including the widgets, plug-ins and other data from the app that you want to remove. It is easier to use since you just need to drag and drop the app that you want to uninstall. It can also help you find relevant files that you also need to remove. Or you may also try AppTrap, when you move your app to the trash it will automatically asked you if you want to move the associated files as well.
I hope this tip will help you.
Martine Paul
